[vcf-midatlantic] GW-DEC-1: A New DEC Prototyping Board
systems_glitch
systems.glitch at gmail.com
Thu Aug 15 12:15:36 EDT 2019
Connector spacing is actually 0.125" (1/8 inch) :) We'd considered using
0.1" dual row headers for the edge connector breakout, it's still an option
but not one I think we're likely to go with.
The purpose of laying out a new prototype board was to get useful
pad-per-hole in production. If you want patterns, you can still buy various
DEC board shapes from Douglas Electronics, most/all of which have various
IC and power patterns on them. In addition to basically being a "style
choice," pad-per-hole is the only thing you can use for e.g. PLCC or PGA
packages. We figured it's better to make one truly universal board and get
the cost down by being able to do at least *some* quantity on the
production run, than having a bunch of different designs that all get ran
in small and expensive batches. Plus, there's the layout time.
Thanks,
Jonathan
On Thu, Aug 15, 2019 at 10:36 AM W2HX <w2hx at w2hx.com> wrote:
> well, my 2 cents. I really love the kinds of protoboards that have power
> rails running either on the outside or under rows of chips. And I really
> love having 3 (or more) pads per connection. Like these. Probably much
> harder to create, but I never liked doing prototyping using 1-hole pads. 3
> or 4 hold pads make building circuits so much easier, IMHO.
> Some examples:
> https://uk.rs-online.com/web/p/breadboards/1596209/
> https://www.alliedelec.com/product/twin-industries/8300sb1/70235136/?gclid=EAIaIQobChMI_uOR3ImF5AIVigOGCh2xngxEEAQYBSABEgLOdvD_BwE&gclsrc=aw.ds
> https://vetco.net/products/protoboard-w-center-bus-strips-1-85-x-2-83
> ________________________________________
> From: vcf-midatlantic <vcf-midatlantic-bounces at lists.vcfed.org> on behalf
> of systems_glitch via vcf-midatlantic <vcf-midatlantic at lists.vcfed.org>
> Sent: Wednesday, August 14, 2019 8:13 PM
> To: vcf-midatlantic
> Cc: systems_glitch
> Subject: [vcf-midatlantic] GW-DEC-1: A New DEC Prototyping Board
> Connor Krukosky and I have been working on laying out a new quad-height DEC
> protoboard, which can also be sheared down into a dual-height board. Full
> announce on the VC Forums:
> http://www.vcfed.org/forum/showthread.php?71177-GW-DEC-1-A-New-Quad-Height-DEC-Prototyping-Board&p=582892#post582892
> These should be available within a month or so. I'll be putting up a
> preorder soon to gauge interest in the production run, which as usual will
> have hard gold plating on the edge connectors. I haven't gotten a quote for
> the cost, but I expect them to be $30-40 each for production boards.
> They'll be available at VCF Midwest as well as online!
> Thanks,
> Jonathan
