[vcf-midatlantic] GW-DEC-1: A New DEC Prototyping Board
W2HX
w2hx at w2hx.com
Thu Aug 15 12:56:45 EDT 2019
?agreed
________________________________
Sent: Thursday, August 15, 2019 12:15 PM
To: W2HX
Cc: vcf-midatlantic
Subject: Re: [vcf-midatlantic] GW-DEC-1: A New DEC Prototyping Board
Connector spacing is actually 0.125" (1/8 inch) :) We'd considered using 0.1" dual row headers for the edge connector breakout, it's still an option but not one I think we're likely to go with.
The purpose of laying out a new prototype board was to get useful pad-per-hole in production. If you want patterns, you can still buy various DEC board shapes from Douglas Electronics, most/all of which have various IC and power patterns on them. In addition to basically being a "style choice," pad-per-hole is the only thing you can use for e.g. PLCC or PGA packages. We figured it's better to make one truly universal board and get the cost down by being able to do at least *some* quantity on the production run, than having a bunch of different designs that all get ran in small and expensive batches. Plus, there's the layout time.
Thanks,
Jonathan
On Thu, Aug 15, 2019 at 10:36 AM W2HX <w2hx at w2hx.com<mailto:w2hx at w2hx.com>> wrote:
well, my 2 cents. I really love the kinds of protoboards that have power rails running either on the outside or under rows of chips. And I really love having 3 (or more) pads per connection. Like these. Probably much harder to create, but I never liked doing prototyping using 1-hole pads. 3 or 4 hold pads make building circuits so much easier, IMHO.
Some examples:
https://uk.rs-online.com/web/p/breadboards/1596209/
https://www.alliedelec.com/product/twin-industries/8300sb1/70235136/?gclid=EAIaIQobChMI_uOR3ImF5AIVigOGCh2xngxEEAQYBSABEgLOdvD_BwE&gclsrc=aw.ds
https://vetco.net/products/protoboard-w-center-bus-strips-1-85-x-2-83
________________________________________
From: vcf-midatlantic <vcf-midatlantic-bounces at lists.vcfed.org<mailto:vcf-midatlantic-bounces at lists.vcfed.org>> on behalf of systems_glitch via vcf-midatlantic <vcf-midatlantic at lists.vcfed.org<mailto:vcf-midatlantic at lists.vcfed.org>>
Sent: Wednesday, August 14, 2019 8:13 PM
To: vcf-midatlantic
Cc: systems_glitch
Subject: [vcf-midatlantic] GW-DEC-1: A New DEC Prototyping Board
Connor Krukosky and I have been working on laying out a new quad-height DEC
protoboard, which can also be sheared down into a dual-height board. Full
announce on the VC Forums:
http://www.vcfed.org/forum/showthread.php?71177-GW-DEC-1-A-New-Quad-Height-DEC-Prototyping-Board&p=582892#post582892
These should be available within a month or so. I'll be putting up a
preorder soon to gauge interest in the production run, which as usual will
have hard gold plating on the edge connectors. I haven't gotten a quote for
the cost, but I expect them to be $30-40 each for production boards.
They'll be available at VCF Midwest as well as online!
Thanks,
Jonathan
