[vcf-midatlantic] [Off Topic] - Vintage computers and UPSes
Dean Notarnicola
dnotarnicola at gmail.com
Tue Aug 20 13:16:03 EDT 2019
I bought a Trip-Lite 2400W power line conditioner. It’s was a bit pricey,
but it corrects for under- and over-voltages, as well as filtering noise
and spikes. Not sure it would save a cap whose time has come, but it gives
me a warm fuzzy about plugging in old gear.
On Tue, Aug 20, 2019 at 12:33 PM Jason Perkins via vcf-midatlantic <
> If you get an APC Smart-UPS, be sure to calibrate the charge voltage. They
> drift over time, and end up cooking the cells:
> http://www.jjoseph.org/notes/apc_smartups_battery_float_voltage
> Thanks,
> On Tue, Aug 20, 2019 at 12:27 PM Dave McGuire via vcf-midatlantic <
> > On 8/20/19 12:23 PM, John Heritage via vcf-midatlantic wrote:
> > > For longevity of vintage computers that are hooked up and powered on
> > > semi-frequently; I assume any kind of UPS is better than none to try
> to
> > > reduce power spikes, or reduce PSU fatigue from brownouts.
> > > I was curious what folks recommendations or thoughts are here? I have
> a
> > > couple of old (~ 15+ year) UPSes that i'm debating replacing the
> > batteries
> > > on, and one of them would be for plugging in some vintage hardware.
> > That's not a bad idea; most UPSes have MOVs in them, and some have
> > decent line filters. Cheap consumer-grade ones typically don't, but
> > those should be in the garbage anyway.
> > A note about MOVs: I generally like MOVs, but they do have one evil
> > aspect: They fail silently, and you won't know that they're no longer
> > doing their jobs.
> > > Is there anything I should watch out for? Should I assume these are
> too
> > > old to effectively monitor/protect - or doesnt' that really matter?
> etc.
> > The UPSes? Many higher-end UPSes from even 20 years ago have serial
> > ports for monitoring.
> > -Dave
> > Dave McGuire, AK4HZ
> > New Kensington, PA
> Jason Perkins
> 313 355 0085
