[vcf-midatlantic] Compaq portable 1
Evan Koblentz
evan at vcfed.org
Fri Aug 23 12:41:57 EDT 2019
It would be great if you guys can pull all the Compaq Portables from the
warehouse and have a fix-a-thon. See how many we can get working from parts
of others.
On Fri, Aug 23, 2019, 12:11 PM Jason Perkins via vcf-midatlantic <
> I can bring my portable if it's a better match - mine is a standard that's
> been upgraded with a HDD.
> I seem to recall it has the "early" motherboard.
> On Fri, Aug 23, 2019 at 11:57 AM David Gesswein via vcf-midatlantic <
> > It was discussed on the list earlier that Doug P was bringing a Compaq
> > portable 1 to work on and I and someone else had offered to bring a
> working
> > machine for comparison. (Mine is a plus). Probable don't need two so
> > checking if that was still desired and if I should bring mine or someone
> > else
> > was bringing a working one. Mine still has covers off.
> Jason Perkins
> 313 355 0085
