[vcf-midatlantic] Compaq Portable 1 (response)
Douglas Perry
djay.perry at gmail.com
Fri Aug 23 12:57:28 EDT 2019
David G thank you for your offer.
I don't think it will be necessary for you to bring the your Compaq.
Considering my current level I if the issue doesn't jump out as obvious
(exploded cap) I don't think I'm capable of tracing it down via comparison.
I do look forward to meeting you though and maybe bending your ear for
ideas depending on what happens when I get it opened up.
Thanks again,
Doug P.
Date: Fri, 23 Aug 2019 11:56:53 -0400
To: vcf-midatlantic at lists.vcfed.org
Subject: [vcf-midatlantic] Compaq portable 1
Message-ID: <20190823155653.GA6583 at hugin2.pdp8online.com>
Content-Type: text/plain; charset=us-ascii
It was discussed on the list earlier that Doug P was bringing a Compaq
portable 1 to work on and I and someone else had offered to bring a working
machine for comparison. (Mine is a plus). Probable don't need two so
checking if that was still desired and if I should bring mine or someone
else
was bringing a working one. Mine still has covers off.
End of vcf-midatlantic Digest, Vol 15, Issue 23
