[vcf-midatlantic] Compaq portable 1
Vincent B
vincentbesse725 at gmail.com
Fri Aug 23 13:04:42 EDT 2019
I have a Portable 286 but it works fine so I'm leaving it at home.
On Fri, Aug 23, 2019, 12:43 PM Evan Koblentz via vcf-midatlantic <
> It would be great if you guys can pull all the Compaq Portables from the
> warehouse and have a fix-a-thon. See how many we can get working from parts
> of others.
> On Fri, Aug 23, 2019, 12:11 PM Jason Perkins via vcf-midatlantic <
> > I can bring my portable if it's a better match - mine is a standard
> that's
> > been upgraded with a HDD.
> > I seem to recall it has the "early" motherboard.
> > On Fri, Aug 23, 2019 at 11:57 AM David Gesswein via vcf-midatlantic <
> > > It was discussed on the list earlier that Doug P was bringing a
> Compaq
> > > portable 1 to work on and I and someone else had offered to bring a
> > working
> > > machine for comparison. (Mine is a plus). Probable don't need two so
> > > checking if that was still desired and if I should bring mine or
> someone
> > > else
> > > was bringing a working one. Mine still has covers off.
> > Jason Perkins
> > 313 355 0085
