[vcf-midatlantic] Compaq Portable 1 (response)
Evan Koblentz
evan at vcfed.org
Fri Aug 23 13:21:22 EDT 2019
>> I don't think I'm capable of tracing it down via comparison.
Yes but helping/teaching each other is what our workshops are all about.
You might still go home with a working computer.
On Fri, Aug 23, 2019, 12:57 PM Douglas Perry via vcf-midatlantic <
> David G thank you for your offer.
> I don't think it will be necessary for you to bring the your Compaq.
> Considering my current level I if the issue doesn't jump out as obvious
> (exploded cap) I don't think I'm capable of tracing it down via comparison.
> I do look forward to meeting you though and maybe bending your ear for
> ideas depending on what happens when I get it opened up.
> Thanks again,
> Doug P.
> Date: Fri, 23 Aug 2019 11:56:53 -0400
> From: David Gesswein <djg at pdp8online.com>
> To: vcf-midatlantic at lists.vcfed.org
> Subject: [vcf-midatlantic] Compaq portable 1
> Message-ID: <20190823155653.GA6583 at hugin2.pdp8online.com>
> Content-Type: text/plain; charset=us-ascii
> It was discussed on the list earlier that Doug P was bringing a Compaq
> portable 1 to work on and I and someone else had offered to bring a working
> machine for comparison. (Mine is a plus). Probable don't need two so
> checking if that was still desired and if I should bring mine or someone
> else
> was bringing a working one. Mine still has covers off.
> End of vcf-midatlantic Digest, Vol 15, Issue 23
