[vcf-midatlantic] Museum AT&T Unix machine
David Gesswein djg at pdp8online.com
Sat Aug 24 08:18:58 EDT 2019
One other thing that probably should be done is to replace the clock
battery or remove it if you don't care about the clock to prevent the damage
from leaking. Its somewhat of a pain to open the case so good to do it at the
same time.  I normally use the BR series vs CR since
they are supposed to be less corrosive chemestry so less likely to leak
though a little less capacity. It's soldered to the motherboard. I don't think
I have any around.
https://www.flickr.com/photos/geekmuseum/sets/72157625198596086
On Sat, Aug 24, 2019 at 07:19:30AM -0400, David Gesswein via vcf-midatlantic wrote:
> On Fri, Aug 23, 2019 at 11:55:19PM -0400, Jeffrey Brace via vcf-midatlantic wrote:
> > If anyone has the expertise to look at and repair the museum AT&T unix
> > machine, it would be much appreciated. The symptoms seem to be that it is
> > endlessly looking for a boot sector and not finding it (based on the
> > symptoms and looking it up on a website). There is a green screen with
> > characters slowly going across endlessly. Please contact Evan or myself if
> > you have the ability and time.
> Is this the 3B1/7300? Have you tried booting the diag floppy? I will bring
> one. Most likely the hard drive has died.
> The drive is normally a Miniscribe 6085 MFM full height 70M drive.
