[vcf-midatlantic] Need to Borrow IBM VGA CRTs for VCF East (8512, 8513, or 8514)
J. Alexander Jacocks jjacocks at gmail.com
Thu Feb 21 12:28:31 EST 2019
Indeed; I am going to run it on as many early PS/2 386es as possible.
- Alex
On Thu, Feb 21, 2019 at 12:21 PM Jameel Akari via vcf-midatlantic <
> >> On Wed, 20 Feb 2019, J. Alexander Jacocks via vcf-midatlantic wrote:
> >> Also if you ever find that your exhibit setup is going /too/ easily and
> >> you're not sufficiently /challenged/ yet, I recommend* installing OS/2
> >> from floppy, or if that's not doing it for you, AIX For PS/2**. ;)
> As now I look at the spreadsheet again and see Alexander is in fact doing
> AIX PS/2. ;)
> Jameel Akari
