[vcf-midatlantic] Sun 3/60 lives again
Mike Loewen
mloewen at cpumagic.scol.pa.us
Thu Jan 3 23:34:16 EST 2019
This has been on my TODO list for years, so it's a good way to start off
the new year. I have a Sun 3/60 with 24MB and CG4 video which I've been
meaning to set up as a diskless client from my Linux server. Until I get a
keyboard adapter cobbled together for a Type 4 keyboard, I'm using a serial
console. Diagnostics all check out from the PROM.
There's a document floating around which describes one user's efforts to
netboot his 3/60:
http://sites.inka.de/pcde/help/sunos_network_boot.html
I used that as a starting point, but it was written in 2004 so there are
additional steps required. For one thing, bootparamd is no longer included in
Fedora Linux (since FC25), so I had to make some changes to the FC24 SRPM for
bootparamd to get it compiled and repackaged for FC28. Also, FC28 by default
has NFS version 2 disabled so you have to change options in /etc/nfs.conf to
enable UDP and version 2.
Here's the console log of it booting SunOS 4.1.1:
Mike Loewen mloewen at cpumagic.scol.pa.us
Old Technology http://q7.neurotica.com/Oldtech/
Boot: le(0,0,0)
Booting from tftp server at 192.168.202.1 = C0A8CA01
Downloaded 101800 bytes from tftp server.
Using IP Address 192.168.202.104 = C0A8CA68
hostname: sun360
domainname: (none)
server name '192.168.202.1'
root pathname '/export/root/sun360'
root on 192.168.202.1:/export/root/sun360 fstype nfs
Boot: vmunix
SunOS Release 4.1.1 (GENERIC) #1: Sat Oct 13 06:05:48 PDT 1990
Copyright (c) 1983-1990, Sun Microsystems, Inc.
mem = 24576K (0x1800000)
avail mem = 23486464
Ethernet address = 8:0:20:0:56:5
si0 at obio 0x140000 pri 2
st0 at si0 slave 32
st1 at si0 slave 40
st2 at si0 slave 24
st3 at si0 slave 16
sr0 at si0 slave 48
sd0 at si0 slave 0
sd1 at si0 slave 1
sd2 at si0 slave 8
sd3 at si0 slave 9
sd4 at si0 slave 16
sd6 at si0 slave 24
zs0 at obio 0x20000 pri 3
zs1 at obio 0x0 pri 3
le0 at obio 0x120000 pri 3
cgfour0 at obmem 0xff300000 pri 4
bwtwo0 at obmem 0xff000000 pri 4
bwtwo0: resolution 1152 x 900
bwtwo1 at obmem 0xff400000
bwtwo1: resolution 1152 x 900
hostname: sun360
domainname: (none)
swap on 192.168.202.1:/export/swap/sun360 fstype nfs size 62500K
dump on 192.168.202.1:/export/swap/sun360 fstype nfs size 62472K
checking filesystems
Automatic reboot in progress...
Fri Jan 4 03:46:34 GMT 2019
checking quotas: done.
starting rpc and net services: portmap keyserv.
mount -vat nfs
mount: 192.168.202.1:/export/exec/sun3.sunos.4.1.1 already mounted
mount: 192.168.202.1:/export/exec/kvm/sun3.sunos.4.1.1 already mounted
192.168.202.1:/export/home mounted on /home
starting additional services: biod.
starting system logger
starting local daemons: auditd sendmail statd lockd.
link-editor directory cache
preserving editor files
clearing /tmp
standard daemons: update cron uucp.
starting network daemons: inetd printer.
Fri Jan 4 03:47:01 GMT 2019
sun360 login: root
Jan 4 03:47:11 sun360 login: ROOT LOGIN console
Last login: Fri Jan 4 03:31:46 on console
sun360# date
Thu Jan 3 22:47:22 EST 2019
sun360# ifconfig -a
le0: flags=63<UP,BROADCAST,NOTRAILERS,RUNNING>
inet 192.168.202.104 netmask ffffff00 broadcast 192.168.202.0
ether 8:0:20:0:56:5
lo0: flags=49<UP,LOOPBACK,RUNNING>
inet 127.0.0.1 netmask ff000000
sun360#
