Re: [vcf-midatlantic] Anyone ever adjust the yoke on a 1970’s Sony trinitron?
Sentrytv sentrytv at yahoo.com
Sat Jan 5 19:18:22 EST 2019
The yoke is held by the clamp yes.
The convergence will be affected by removing the wedges.
They are used to tweak the purity (of red) and convergence.
If you move the yoke at all the convergence and possibly purity will be changed.
It my take some time but you should be able to " get it back".
You could bring it to the workshop
Plenty  of people to help I'm sure.
Mike R.
Sent from:
My extremely complicated, hand held electronic device.
> On Jan 5, 2019, at 3:59 PM, corey cohen via vcf-midatlantic <vcf-midatlantic at lists.vcfed.org> wrote:
> So I have a 1974-75ish Sony KV-9200 color Trinitron TV and I need to rotate the yoke a little because the image is crooked.  I removed the rubber wedges but the yoke won’t budge.  I decided to walk away for a few hours and just took another look and I did just notice there is a small clamp on the end of the tube neck that could be loosened up, but before I do that I was wondering if that is what it’s intended for to hold the yoke in place against the rubber wedges?  I don’t want to have to adjust the convergence so I haven’t loosed it yet just Incase that is wrong.  I’m also worried because the neck is the most fragile part of the tube and don’t want to break it.
> This is all I have left to do on this TV.  I replaced every electrolytic cap, adjusted b+, cleaned all the controls and refreshed the entire exterior.
> Any advise would be helpful.
> Thanks,
> Corey
> corey cohen
> uǝɥoɔ ʎǝɹoɔ
> Sent from my iPhone
