[vcf-midatlantic] SGI Indigo help at tomorrow's workshop (Saturday)
dillera at gmail.com
Fri Jan 11 09:50:04 EST 2019
I can 100% get you irix 6.5.22 installed on that, as I've done it many times. No cdrom required.
Make sure you have an AAUI to 10bt adapter to get the indigo onto a local lan via ethernet 10bt and we can install you a full set w/ all dev tools and MIPS pro compliers and license.
I will bring a serial cable and there is no need for K/M/V with serial- but you may want to see it.
-andy
> On Jan 11, 2019, at 9:20 AM, Adam Michlin via vcf-midatlantic <vcf-midatlantic at lists.vcfed.org> wrote:
> Hi Everyone,
> I'm bringing my SGI Indigo to the workshop. Known working CPU, keyboard, RAM and hard drives. Possibly working mouse (likely). Two appropriate CD-ROM drives that don't seem to work (with caddies).
> I'm just trying to get IRIX installed so I can do some MIPS programming on real hardware. If any one can bring appropriate installation CDs and a known working external CD-ROM, it would be greatly appreciated.
> Thanks,
> -Adam
