[vcf-midatlantic] Tandy 6000
Peter Cetinski pete at pski.net
Fri Jan 11 13:38:36 EST 2019
It’s 19 disks for Xenix 3.2 with the 3.0 dev system, Dean!  :) You really want that because without it Tandy Xenix is mostly just a runtime system.  A few of the install disks are double sided as well.
I highly recommend getting an HxC floppy emulator for the 6000.  The full Xenix install will push your TM-848 drive to the max.
Also a good idea to image the diagnostics disk first so you can run the full test suite of 68k diags before attempting the Xenix install.
Pete
> On Jan 11, 2019, at 1:29 PM, Ian Primus via vcf-midatlantic <vcf-midatlantic at lists.vcfed.org> wrote:
> I can bring my disk imaging setup, which can write those disks.
> -Ian
> On Friday, January 11, 2019, Dean Notarnicola via vcf-midatlantic <
>> I'll be bringing a Tandy 6000 to the workshop in addition to the Mac Color
>> Classic II that I'll be attempting to restore. Would anyone have a set of
>> TRSDOS II 4.2/4.3 or TRS-Xenix 3 (preferably) disks? I have some blank 8" I
>> can use to copy them, or I'd be very happy to compensate someone for a set
>> of one or both.
>> - Dean
