[vcf-midatlantic] Tandy 6000
Dean Notarnicola dnotarnicola at gmail.com
Fri Jan 11 13:58:38 EST 2019
Of course, you are correct. I have a Gotek handy. Do you happen to know if
the flashfloppy firmware makes it compatible with the 6000?
- Dean
On Fri, Jan 11, 2019 at 1:39 PM Peter Cetinski via vcf-midatlantic <
> It’s 19 disks for Xenix 3.2 with the 3.0 dev system, Dean!  :) You really
> want that because without it Tandy Xenix is mostly just a runtime system.
> A few of the install disks are double sided as well.
> I highly recommend getting an HxC floppy emulator for the 6000.  The full
> Xenix install will push your TM-848 drive to the max.
> Also a good idea to image the diagnostics disk first so you can run the
> full test suite of 68k diags before attempting the Xenix install.
> Pete
> > On Jan 11, 2019, at 1:29 PM, Ian Primus via vcf-midatlantic <
> > I can bring my disk imaging setup, which can write those disks.
> > -Ian
> > On Friday, January 11, 2019, Dean Notarnicola via vcf-midatlantic <
> >> I'll be bringing a Tandy 6000 to the workshop in addition to the Mac
> Color
> >> Classic II that I'll be attempting to restore. Would anyone have a set
> of
> >> TRSDOS II 4.2/4.3 or TRS-Xenix 3 (preferably) disks? I have some blank
> 8" I
> >> can use to copy them, or I'd be very happy to compensate someone for a
> set
> >> of one or both.
> >> - Dean
