[vcf-midatlantic] SGI Indigo help at tomorrow's workshop (Saturday)
Ethan O'Toole telmnstr at 757.org
Fri Jan 11 16:04:00 EST 2019
> Just to you... thanks again!
> Are you sure 6.* will work? I seem to remember that I was told this is one of
> earliest models of the SGI Indigo (maybe R3000?) and might only go work with
> 5.*?
If it is a R3K CPU board then your optical drive has to be 512 byte
blocks, and you are limited to IRIX 5.3 I think.
Check the left board by model #.
 			- Ethan
