[vcf-midatlantic] SGI Indigo help at tomorrow's workshop (Saturday)
dillera at gmail.com dillera at gmail.com
Fri Jan 11 16:08:01 EST 2019
True -
If it's a R3k it will have to be 5.3.
If it's a R4k it can be 6.5.22.
You can tell by hinv in the PROM or by looking at the SIMM RAM- the R4k takes regular SIMMS, the R3k has larger proprietary SIMMS.
We will install either 5.3 or 6.5 tomorrow via netbook - no CDROM is required.
-andy
> On Jan 11, 2019, at 4:04 PM, Ethan O'Toole via vcf-midatlantic <vcf-midatlantic at lists.vcfed.org> wrote:
>> Just to you... thanks again!
>> Are you sure 6.* will work? I seem to remember that I was told this is one of earliest models of the SGI Indigo (maybe R3000?) and might only go work with 5.*?
> If it is a R3K CPU board then your optical drive has to be 512 byte blocks, and you are limited to IRIX 5.3 I think.
> Check the left board by model #.
> 			- Ethan
