[vcf-midatlantic] Tandy 6000
J. Alexander Jacocks jjacocks at gmail.com
Sat Jan 12 19:04:20 EST 2019
Also, don't forget that the HxC firmware is available for the Gotek, making
it just as compatible as the real HxC drives, if not quite as well made and
attractive.
- Alex
On Fri, Jan 11, 2019 at 2:28 PM Peter Cetinski via vcf-midatlantic <
> Not sure about the Gotek.  I know the standard HxC works well with the 8”
> Tandy’s.
> Pete
> > On Jan 11, 2019, at 1:58 PM, Dean Notarnicola <dnotarnicola at gmail.com>
> wrote:
> > Of course, you are correct. I have a Gotek handy. Do you happen to know
> if the flashfloppy firmware makes it compatible with the 6000?
> > - Dean
> >> On Fri, Jan 11, 2019 at 1:39 PM Peter Cetinski via vcf-midatlantic <
> >> It’s 19 disks for Xenix 3.2 with the 3.0 dev system, Dean!  :) You
> really want that because without it Tandy Xenix is mostly just a runtime
> system.  A few of the install disks are double sided as well.
> >> I highly recommend getting an HxC floppy emulator for the 6000.  The
> full Xenix install will push your TM-848 drive to the max.
> >> Also a good idea to image the diagnostics disk first so you can run the
> full test suite of 68k diags before attempting the Xenix install.
> >> Pete
> >> > On Jan 11, 2019, at 1:29 PM, Ian Primus via vcf-midatlantic <
> >> > I can bring my disk imaging setup, which can write those disks.
> >> > -Ian
> >> > On Friday, January 11, 2019, Dean Notarnicola via vcf-midatlantic <
> >> >> I'll be bringing a Tandy 6000 to the workshop in addition to the Mac
> Color
> >> >> Classic II that I'll be attempting to restore. Would anyone have a
> set of
> >> >> TRSDOS II 4.2/4.3 or TRS-Xenix 3 (preferably) disks? I have some
> blank 8" I
> >> >> can use to copy them, or I'd be very happy to compensate someone for
> a set
> >> >> of one or both.
> >> >> - Dean
