[vcf-midatlantic] SGI Indigo help at tomorrow's workshop (Saturday)
Adam Michlin
amichlin at swerlin.com
Mon Jan 14 20:56:03 EST 2019
Yes, a public thank you to Andy for saving my Indigo R3000!
Now I just need to figure out how to install a C compiler on Irix 5.3.
Not as easy as I expected!
-Adam
On 1/14/2019 8:46 AM, andy diller via vcf-midatlantic wrote:
> The SGI Install area was actually a win, as we managed to go thru a bunch of drives and SCSI magic to get Adam's Indigo working with a fresh, full install of 5.3.
> We also pulled out the VCF's SGIs and discovered they have a Iris 4d, Indigo 1 R4k (may be elan) and a Teal Indigo2.
> I ran out of time, but I am targeting next Feb workshop to:
> - bring up some SCSI2SD drives for the VCF's SGI systems
> - boot them (if they work- we didn't test)
> - install fresh OS of 5.3 or 6.5.22 depending on RAM via my netboot (so no CDROM are required)
> If anyone else is interested in SGI please come up for Feb.
> I will also have my RS/6000 43P by then and will bring it to mess around with. I've gotten rid of 95% of my stuff (thanks for everyone that bid, won showed up and paid and took the stuff) and now I can focus on actual repair work and slow prepping for the festival.
> Some Photos:
> Adam logging into his Indigo for the very first time ever, with IRIX 5.3
> Behind there you can see my MacBook, which was running the virtual server (debian box) that ran DHCP/BOOTP and TFTP which allowed a complete netboot and install on the SGIs. It will work with the Iris 4D, as I have one and the PROM is capable of doing it!
> See you Feb.
> -andy
>> On Jan 11, 2019, at 4:04 PM, Ethan O'Toole via vcf-midatlantic <vcf-midatlantic at lists.vcfed.org> wrote:
>>> Just to you... thanks again!
>>> Are you sure 6.* will work? I seem to remember that I was told this is one of earliest models of the SGI Indigo (maybe R3000?) and might only go work with 5.*?
>> If it is a R3K CPU board then your optical drive has to be 512 byte blocks, and you are limited to IRIX 5.3 I think.
>> Check the left board by model #.
>> - Ethan
