[vcf-midatlantic] does anyone have one of these badges or know how to order more?
Duane Craps DBC1964 at cox.net
Thu May 2 10:53:12 EDT 2019
Jeff,
Looks like it would be a pain for a long tape. You would have to clamp
it in a vice or something.
I built a pull through reader with just a photo-transistor array pulling
down a Arduino's internal pull-up resistor.
I ordered one of these:
https://www.ebay.com/itm/RICOH-DENSHI-2400-2-PTR-240-05-CNC-EDM-2400-2-TAPE-READER-MITSUBISHI-EDM/163197432844?hash=item25ff53340c:g:POAAAOSw5cRZL0pb
They require 24 VDC for the stepping motor and 5 VDC for the logic.
It seems to have the same 50 pin connector  as the pinch roller unit
that I hacked earlier (same as SCSI).
If so all I have to find is the Run/Stop and the Direction signals.
The pinch roller had a switch for Run/Stop so I did not have to find that
Duane
On 5/1/2019 11:16 PM, Jeffrey Jonas via vcf-midatlantic wrote:
> I'd love to get 1 or 2 of these paper tape reader convention-badges:
> https://hackaday.com/2019/04/12/cyphercon-badge-has-a-paper-tape-reader-built-in/
> Does anyone have one, or know how to order more?
> Please tell me!
> thanks
> -- jeff jonas
Duane Craps
sdɐɹɔ ǝuɐnp
> Please tell me!
> thanks
> -- jeff jonas
DuaneCraps
sdɐɹɔ ǝuɐnp
