[vcf-midatlantic] Help with installing 1980s DOS program
Devin Heitmueller devin.heitmueller at gmail.com
Mon May 13 21:49:14 EDT 2019
It might be worth mentioning that if the user is getting this app
up-and-running in order to get access to existing files, there are
tools out there which can convert Leading Edge files into more modern
formats.
At least, that's what a Google search found:
http://www.classiccmp.org/pipermail/cctech/2015-March/003841.html
https://sourceforge.net/p/transformenator/git/ci/master/tree/src/org/transformenator/transforms/leading_edge_rtf
I would assume there's a good chance that the user isn't so much
interested in using an ancient word processor for nostalgia, but
rather to gain access to some old documents.
Devin
On Mon, May 13, 2019 at 9:43 PM Evan Koblentz via vcf-midatlantic
<vcf-midatlantic at lists.vcfed.org> wrote:
> >> PROMPT $P$G
> What is that part?
> On Mon, May 13, 2019, 9:40 PM Ethan O'Toole <telmnstr at 757.org> wrote:
> > > Now all I need to do is edit (autoexec.bat?) with a path line, if fuzzy
> > > college memory serves me correctly, in order for this to work right from
> > > c:\.
> > If dos is in C:\DOS:
> > PATH=C:\DOS;C:\yourprogram;etc
> > PROMPT $P$G
> > It's amazing how much we forget about things we grew up using and hacking
> > around on everyday!
> > Apparently lawyers were big on DOS era word processors (Word Perfect)
> > because of forms they have where they fill in items and it populates them
> > or something. The same thing exists of course in modern systems but change
> > is hard and not always better.
> >                 - Ethan
Devin J. Heitmueller
http://www.devinheitmueller.com
