[vcf-midatlantic] Scopewriter Issue Resolved.
Herb Johnson hjohnson at retrotechnology.info
Mon May 20 12:15:47 EDT 2019
> It’s interesting how many of the hobby designed products from the mod 70’s have marginal aspects to their designs.  Whenever anyone recreates or restores any old electronic device, it often can be a tricky problem to determine whether a problem is introduced or original to the design
> regards,
> Mike Willegal
The very earliest microcomputers or microprocessor-based things from the
early to mid-1970's, were often designed by people new to
microprocessors and/or TTL logic. Some of course (TV Typewriter)  were
all TTL logic. The very earliest microprocessors needed odd voltages and
timings. So some of the logic design was a bit, er, funky.
A common practice was to use a resistor/capacitor circuit (R/C circuit)
to create timing delays, or turn level-shifts into pulses. These don't
age well, and didn't work well when new. The IMSAI front panel has a
couple of these. Also, "straight" TTL draws a lot of current; later
LSTTL and much later ALSTTL draws less current and is faster. Early CMOS
was challenging too.
Things got better, later on. And some brands (Compupro, etc.) produced
pretty solid designs from the start. These are restorer's considerations
which aren't documented. It's part of the fun, in my opinion.
Notably,
Herb Johnson
or try later herbjohnson AT retrotechnology DOT info
