[vcf-midatlantic] Binocular Loupe vs Microscope for vintage electronics repair
alan at alanlee.org alan at alanlee.org
Sun May 26 21:30:17 EDT 2019
Yes on the .5.  My scope is clamped to the back of a table pushed
against a wall and it's hard to scoot out.  I estimate the jaw to open
to about 1.75".  So it wont fit on your bench unmodified.
-Alan
On 2019-05-26 20:20, corey cohen wrote:
> Thanks. Do you use the .5 Barlow to get the large working distance? Or do you leave it off?
> Also how wide is the clamp?   I have a small piece of oak securely attached to my workbench for my current magnifier's articulating arm. The table is too thick otherwise.  I was hoping to use that mounting point for the scope.  It's about 2.5" wide. Is the clamp wider than that?
> Thanks,
> Corey
> corey cohen
> uǝɥoɔ ʎǝɹoɔ
> Sent from my iPhone
