[vcf-midatlantic] B&C Microsystems EEPROM software
Matt Reynolds mattreynolds04 at gmail.com
Mon May 27 16:26:53 EDT 2019
Herb,
It's vintage, which is why I thought I'd take a stab at asking you folks.
The motherboard says it was made in 1989.
1.  It is screen printed in the name on the device that it is rs-232.
2.  I can try and use PuTTY and see if that works but I'm sure it needs
more than that.
3.  I'm trying to set this device up so i can read\burn EEPROMS, so I'd
have to buy\use something else to read the one inside of it..  There is an
8085 processor in it.  There is also an 8155 and 8251.
4.  This may have been common in the past, but I'm only four years older
than the device itself.  I've never had to do it, I'm trying to learn about
it, which is why I bought it in the first place :)
I am not giving up hope that the software is out there somewhere.  The
software for it's more expensive relative is on bitsavers, I will probably
try and install it and see what it does regardless.  Maybe I'll get lucky
and it will work.  I'll also try the straight up serial connection and see
what happens.
Thanks,
Matt
On Mon, May 27, 2019, 3:34 PM Herb Johnson via vcf-midatlantic <
> >  software
> > that goes with a B&C Microsystems Inc. UP100 Universal RS232
> E(E)PROM/Micro
> > Programmer.
> If this is some modern unit with a single-chip microcontroller, you are
> probably out of luck. If not, if it's vintage enough to have a
> microprocessor and some ROM and some RAM:
> 1) confirm the unit is "RS-232" or serial. Many of them used a PC
> parallel port. YOu'll have to reverse engineer the circuits at the DB25
> (or DB9) connector.
> 2) If it's really serial, chances are it can be operated with a serial
> terminal (or PC running a comm program). You may have to guess at the
> baud rates, it may be autobaud, using the first character received to
> determine a baud rate. "Hit return a lot.".
> If it's PC parallel, you are mostly out of luck. But there's still:
> 3) if all that fails, Pull the PROM out of the unit - chances are it has
> one - and dump it. Of course you'll need an EPROM reader, once, to do
> this. Also note the processor in the unit. You may need to disassemble
> the code, at least a little. But it may be informative even as an ASCII
> dump.
> - Um, this is the kind of thing done, lots of time in the past, to make
> sense of some unknown microcomputer. Is this "lost art" now?
> Puzzled,
> Herb Johnson
> Herbert R. Johnson, New Jersey in the USA
> http://www.retrotechnology.com OR .net
