[vcf-midatlantic] Museum report
corey cohen
coreyvcf at gmail.com
Wed Nov 20 19:59:36 EST 2019
Why is someone changing the Apple II TV from UHF channel 33? I did put a red mark on the dial so it’s very obvious what you need to set it to.
corey cohen
uǝɥoɔ ʎǝɹoɔ
Sent from my iPhone
> On Nov 20, 2019, at 6:56 PM, Jeffrey Brace via vcf-midatlantic <vcf-midatlantic at lists.vcfed.org> wrote:
> On Sun, Nov 17, 2019 at 10:23 PM Evan Koblentz via vcf-midatlantic <
>> I was unable to get four things to work:
>> - Apple II (crazy display)
> I got this working. I changed the channel to 33 and adjusted the contrast.
> Now it works fine.
>> - Apple III (no display)
> This isn't working. It is plugged in, but appears to have no power. Perhaps
> a power supply issue. Tony or others may need to look at it next workshop
> or when they have time as docent.
>> - OSI Challenger (no display)
> Didn't have time to check this one.
>> - Atari 1040 (no display)
> When I changed the input back to TV it worked fine.
