[vcf-midatlantic] Museum report
Evan Koblentz evan at vcfed.org
Wed Nov 20 20:07:37 EST 2019
>> I changed the channel to 33 and adjusted the contrast. Now it works fine.
Good work.
>> - Apple III (no display) This isn't working. It is plugged in, but
appears to have no power. Perhaps
a power supply issue. Tony or others may need to look at it next
workshop or when
they have time as docent.
Okay.
>> Atari 1040 (no display) When I changed the input back to TV it worked
fine.
Oh, I thought they had to be on A/V.
On Wed, Nov 20, 2019, 7:55 PM Jeffrey Brace via vcf-midatlantic <
> On Sun, Nov 17, 2019 at 10:23 PM Evan Koblentz via vcf-midatlantic <
> > I was unable to get four things to work:
> > - Apple II (crazy display)
> I got this working. I changed the channel to 33 and adjusted the contrast.
> Now it works fine.
> This isn't working. It is plugged in, but appears to have no power. Perhaps
> a power supply issue. Tony or others may need to look at it next workshop
> or when they have time as docent.
> > - OSI Challenger (no display)
> Didn't have time to check this one.
> > - Atari 1040 (no display)
> When I changed the input back to TV it worked fine.
