[vcf-midatlantic] Museum report
Evan Koblentz
evan at vcfed.org
Wed Nov 20 20:12:56 EST 2019
Dunno, wasn't me!
> changing the Apple II TV from UHF channel 33? I did put a red mark on
> the dial so it’s very obvious what you need to set it to.
> corey cohen
> uǝɥoɔ ʎǝɹoɔ
> Sent from my iPhone
> > On Nov 20, 2019, at 6:56 PM, Jeffrey Brace via vcf-midatlantic <
> vcf-midatlantic at lists.vcfed.org> wrote:
> > On Sun, Nov 17, 2019 at 10:23 PM Evan Koblentz via vcf-midatlantic <
> >> I was unable to get four things to work:
> >> - Apple II (crazy display)
> > I got this working. I changed the channel to 33 and adjusted the
> contrast.
> > Now it works fine.
> >> - Apple III (no display)
> > This isn't working. It is plugged in, but appears to have no power.
> Perhaps
> > a power supply issue. Tony or others may need to look at it next workshop
> > or when they have time as docent.
> >> - OSI Challenger (no display)
> > Didn't have time to check this one.
> >> - Atari 1040 (no display)
> > When I changed the input back to TV it worked fine.
