[vcf-midatlantic] Stupid CP/M question
Jeff Galinat jgalinat at gmail.com
Sat Aug 1 22:35:33 EDT 2020
Hi Rich,
  I'm not the sharpest guy with this stuff so take this with a grain of
salt but can't you use pip to capture the source file sent as a ascii text
file via the con device?
Regards,
Jeff Galinat
On Sat, Aug 1, 2020, 6:39 PM Richard Cini via vcf-midatlantic <
> All —
> I just built myself a CompuPro Z80 system out some of my spare boards. It
> boots CP/M from one of the Maslin 8” disk images. To facilitate getting
> other programs onto the disk, I want to use XMODEM from Marty Eberhard. It
> compiles with CP/M ASM which is good, but what’s the best way of getting
> the source file onto the disk?
> It’s not clear if the CBIOS has code for a separate PUN/RDR port. I was
> thinking of using ED and then, using HyperTerminal, paste the source into
> the ED screen and save it.
> I looked at the manual for ED and it’s not clear to me if I can actually
> do that, so I wanted to ask the group if that’s a good way or if there’s
> something better.
> Thanks!
> Rich
> Get Outlook for iOS<https://aka.ms/o0ukef>
