[vcf-midatlantic] keyboard cable for Kaypro
RETRO Innovations go4retro at go4retro.com
Sat Aug 1 23:15:44 EDT 2020
On 8/1/2020 9:47 PM, Sentrytv wrote:
> If you could sent me info where you found it that would be helpful.
> Thanks
> Mike R.
> Sent from:
> My extremely complicated, hand held electronic device.
Interestingly, I was looking in my connectors stash for something else
(DB25 shield), and it was lying on top:
https://www.mouser.com/ProductDetail/Hirose-Connector/TM1R-616P44-35S-150M?qs=%2Fha2pyFadujL3%2FLF4U%252BCepaf%252Bt2HANiGebY1zL1ksbDnWXn40xAxPXJ5IvnyL7KG
The default pic is not correct, but look at the datasheet,and mine are
even the same color gray as the original.
I ended up just pulling the original pins out of the old conn and
putting them in the new one, but you can also solder/splice the ones
that come with the units.
Jim
