[vcf-midatlantic] Apple IIgs “safe mode”
Richard Cini
rich.cini at gmail.com
Sun Aug 16 13:31:15 EDT 2020
It turns out you need to go into the startup control panel by holding Option and make sure the startup is set for slot 6 (floppy) and not “scan”. I ordered a new PRAM battery for it since it was dead. For some reason it won’t recognize the SCSI drive from the install disks but it will try to boot off of it. When booting from the HD, it gets half-way and complains about missing FST files and tries to access a floppy for them.
More to do on it, but that’s just to prep it to get rid of it. It’s a complete system: monitor, 4 floppy drives, one HD, SystemSaver, extra RAM and the external SCSI. It did boot System 6.0.1.
Rich
Get Outlook for iOS<https://aka.ms/o0ukef>
________________________________
Sent: Saturday, August 15, 2020 9:22:33 PM
To: vcf-midatlantic <vcf-midatlantic at lists.vcfed.org>
Cc: Richard Cini <rich.cini at gmail.com>
Subject: Re: [vcf-midatlantic] Apple IIgs “safe mode”
Try holding down the ‘esc’ key on power on. This should force boot from floppy.
On Sat, Aug 15, 2020 at 5:05 PM Richard Cini via vcf-midatlantic <vcf-midatlantic at lists.vcfed.org<mailto:vcf-midatlantic at lists.vcfed.org>> wrote:
I’m trying to prep my old //gs for possibly getting rid of it. It’s been sitting for a while but it passes internal diagnostics. It seems to be barfing on loading GSOS from the external SCSI so I was wondering if there’s a way to force it to boot from the floppy disk so I can reformat the drive.
Thanks!
Rich
