[vcf-midatlantic] Atari XE game system
Dean Notarnicola
dnotarnicola at gmail.com
Wed Aug 19 13:42:02 EDT 2020
99% isopropyl will leave little residue of consequence. I get it from
Amazon.
On Wed, Aug 19, 2020 at 12:59 PM Ethan O'Toole via vcf-midatlantic <
> Oh man Atari 8bit stuff is cool AM I RIGHT friends!??!
> > Can anyone help me get this to boot correctly and play other games?
> On the carts... try using something like deoxit on a qtip to wipe the
> contacts on a cart. While it's wet with deoxit, insert and remove it from
> the cart slot. It might just be that it's not making good contact so the
> games aren't executing properly.
> A pencil eraser might clean the cart side. Rubbing alcohol on a qtip is
> another thing but dunno if that would leave a coating. Deoxit is my go-to.
> It's a tid bit expensive and use it around open air or a fan.
> I have never owned an XE game system, but maybe it doesn't have a ROM
> BASIC for when there is no game. If one game works that is a pretty
> good sign.
> I had a huge pile of carts from a thrift store haul maaany years ago and
> pretty much none of them worked until I cleaned all of the contacts.
> Note, original atari carts require the insertion of two screwdrivers or
> similar to open the door and access the circuit board. I would try not to
> open the carts since that harms the label.
> - Ethan
