[vcf-midatlantic] ISA BIOS extension board?
Dean Notarnicola dean.notarnicola at vcfed.org
Thu Feb 6 21:45:59 EST 2020
XT-IDE should work for you
On Thu, Feb 6, 2020 at 9:09 PM Richard Cini via vcf-midatlantic <
> All –
>                 I have an old 486 “shoe box”/industrial PC from 1994 that
> I want to toss a larger hard drive in to use with some Windows 3.11
> experiments I’m doing. Unfortunately, it doesn’t have LBA BIOS extensions,
> so I’m capped at 540MB. I have one from WD, but it’s kind of creaky. So, I
> pulled out a 1.2G drive I had and installed OnTrack 9.57 which works fine.
> However, I feel kind of funny relying on the software wedge because you
> need to make custom boot diskettes, etc.
>                 So, I was looking for an ISA card with the LBA BIOS
> extensions. I know they made them years ago, but I don’t know exactly what
> they are called, so I’m not having much success in locating one.
> There may be other options like using an XT-IDE (if it does LBA; can’t
> tell) or maybe a different IDE card. Problem is that space is very limited
> (only 3 slots) and it has to be a low/short card to avoid interfering with
> the CPU fan.
> Any other suggestions/advice welcome. Right now I’m going to run with the
> 540MB drive I have, but I would like to find a better solution.
> Thanks!
> Rich
> Rich Cini
> http://www.classiccmp.org/cini
> http://www.classiccmp.org/altair32
