[vcf-midatlantic] The Print Shop for the C64 - known working copy?
Jeffrey Brace jeffrey at vcfed.org
Wed Feb 12 20:25:08 EST 2020
Hello,
I setup The Print Shop for the C64 in the museum with the original disk,
but it locked after successful test print in the printer setup part. I
tried two cracked versions, but they didn't have the setup part in the menu
or didn't work.
Does someone have a known working copy? Can you send it as a .d64? I will
be at the System Source repair workshop this weekend if that helps deliver
a real floppy disk.
Jeff Brace
Vice President & Board Member, VCF East Showrunner
Vintage Computer Federation
http://www.vcfed.org/
