[vcf-midatlantic] Sol 20 update
corey cohen coreyvcf at gmail.com
Wed Mar 18 11:39:28 EDT 2020
Why aren’t you loading programs though the cassette port or putting the machine into “non-local” mode and using the serial port to “virtually” type in programs?
corey cohen
uǝɥoɔ ʎǝɹoɔ
Sent from my iPhone
> On Mar 17, 2020, at 5:57 PM, Mike Loewen via vcf-midatlantic <vcf-midatlantic at lists.vcfed.org> wrote:
>   My Sol 20 is up and running:
> http://q7.neurotica.com/Oldtech/S100/Sol20/
>   As expected, I had to replace all of the foam pads in the keyboard. For some reason, the TexElec pads hardly worked at all so I sacrificed a Sun Type 4 keyboard for its pads. Other than that, a couple of RAM problems (dirty DIP switch and a defective 74LS157 multiplexer) were all that I had to fix.
>   As time permits, I'll investigate getting a couple of 8" drives working with a Micromation Doubler board. For now, I'm loading programs through the serial port at 1200 baud.
> Mike Loewen                mloewen at cpumagic.scol.pa.us
> Old Technology                http://q7.neurotica.com/Oldtech/
