[vcf-midatlantic] Sol 20 update
corey cohen
coreyvcf at gmail.com
Wed Mar 18 15:57:33 EDT 2020
Yes. I misunderstood, that is one way to load software.
corey cohen
uǝɥoɔ ʎǝɹoɔ
Sent from my iPhone
> On Mar 18, 2020, at 1:07 PM, Mike Loewen via vcf-midatlantic <vcf-midatlantic at lists.vcfed.org> wrote:
> Isn't that what I'm doing, "virtually" typing the programs througn the serial port? I'm setting the Sol input to serial (SET I=1), then sending the ENT as an ASCII file from another computer to the Sol's serial port.
>> On Wed, 18 Mar 2020, corey cohen wrote:
>> Why aren?t you loading programs though the cassette port or putting the machine into ?non-local? mode and using the serial port to ?virtually? type in programs?
>> corey cohen
>> u??o? ???o?
>> Sent from my iPhone
>>>> On Mar 17, 2020, at 5:57 PM, Mike Loewen via vcf-midatlantic <vcf-midatlantic at lists.vcfed.org> wrote:
>>> My Sol 20 is up and running:
>>> http://q7.neurotica.com/Oldtech/S100/Sol20/
>>> As expected, I had to replace all of the foam pads in the keyboard. For some reason, the TexElec pads hardly worked at all so I sacrificed a Sun Type 4 keyboard for its pads. Other than that, a couple of RAM problems (dirty DIP switch and a defective 74LS157 multiplexer) were all that I had to fix.
>>> As time permits, I'll investigate getting a couple of 8" drives working with a Micromation Doubler board. For now, I'm loading programs through the serial port at 1200 baud.
>>> Mike Loewen mloewen at cpumagic.scol.pa.us
>>> Old Technology http://q7.neurotica.com/Oldtech/
