[vcf-midatlantic] Sol 20 update
corey cohen
coreyvcf at gmail.com
Thu Mar 19 15:18:44 EDT 2020
OK you guys can download from here…
http://myapplecomputer.net/SOL20/Sol20_AudioFiles.zip <http://myapplecomputer.net/SOL20/Sol20_AudioFiles.zip>
When I get a chance, I’ll create a menu item on my website for this so people who don’t have the direct URL can find it, but for now enjoy…
Cheers,
Corey
> On Mar 19, 2020, at 2:37 PM, corey cohen <coreyvcf at gmail.com> wrote:
> I’ll try to figure out a place I can put them that would be around for a while and then post it.
> corey cohen
> uǝɥoɔ ʎǝɹoɔ
> Sent from my iPhone
>> On Mar 19, 2020, at 7:14 AM, Mike Loewen via vcf-midatlantic <vcf-midatlantic at lists.vcfed.org> wrote:
>> I haven't looked at the cassette circuitry yet, but will eventually get there. Thanks for the offer.
>> On Wed, 18 Mar 2020, corey cohen wrote:
>>> Did you calibrate your cassette interface? I can send you a bunch of software on audio files. You can play them right in front an MP3 player, iPod or smart phone.
>>> corey cohen
>>> u??o? ???o?
>>> Sent from my iPhone
>>>> On Mar 18, 2020, at 3:57 PM, corey cohen <coreyvcf at gmail.com> wrote:
>>>> Yes. I misunderstood, that is one way to load software.
>>>> corey cohen
>>>> u??o? ???o?
>>>> Sent from my iPhone
>>>>>> On Mar 18, 2020, at 1:07 PM, Mike Loewen via vcf-midatlantic <vcf-midatlantic at lists.vcfed.org> wrote:
>>>>> Isn't that what I'm doing, "virtually" typing the programs througn the serial port? I'm setting the Sol input to serial (SET I=1), then sending the ENT as an ASCII file from another computer to the Sol's serial port.
>>>>>> Why aren?t you loading programs though the cassette port or putting the machine into ?non-local? mode and using the serial port to ?virtually? type in programs?
>>>>>> corey cohen
>>>>>> u??o? ???o?
>>>>>> Sent from my iPhone
>>>>>>>> On Mar 17, 2020, at 5:57 PM, Mike Loewen via vcf-midatlantic <vcf-midatlantic at lists.vcfed.org> wrote:
>>>>>>> My Sol 20 is up and running:
>>>>>>> http://q7.neurotica.com/Oldtech/S100/Sol20/
>>>>>>> As expected, I had to replace all of the foam pads in the keyboard. For some reason, the TexElec pads hardly worked at all so I sacrificed a Sun Type 4 keyboard for its pads. Other than that, a couple of RAM problems (dirty DIP switch and a defective 74LS157 multiplexer) were all that I had to fix.
>>>>>>> As time permits, I'll investigate getting a couple of 8" drives working with a Micromation Doubler board. For now, I'm loading programs through the serial port at 1200 baud.
>>>>>>> Mike Loewen mloewen at cpumagic.scol.pa.us
>>>>>>> Old Technology http://q7.neurotica.com/Oldtech/
