[vcf-midatlantic] How To Geek article on floppy data recovery
Herb Johnson
hjohnson at retrotechnology.info
Fri May 8 12:38:20 EDT 2020
On 5/8/2020 12:04 PM, Dean Notarnicola wrote:
> However, consider that, over time, it may matter less and less as a
> larger volume of old media gets archived. Maybe it’s ok that these
> devices are somewhat ephemeral. Just food for thought.
If I accept that proposition, Dean: vintage computing may matter less
and less, as a larger volume of information and actual computers get
archived in collections and on Web pages. Maybe it's OK that everything
is ephemeral - including you and me. That's called "carrying an argument
to its logical conclusions". Or to extreme conclusions, you decide.
The weaker response, is that many people have decided that floppy
diskettes are so obsolete, one should simply archive their contents and
avoid their use. In that case, the fact that archival mechanisms come
and go - these various microcontrollers - doesn't matter either. One
finds a means to archive or recover; one does the recovery; one moves on.
I have a few Web pages, about the efforts needed to "archive", and then
recover and put to use, various inconvenient floppy disk formats; such
as M2FM or MMFM and Intel Multibus system disks. Eventually, the
recovery was performed by *actual period hardware and Intel systems*.
Your mileage may vary, regarding your favorite vintage systems.
Again, I call out the difference between vintage computing as acts of
preservation; and modern computing as an "ephemeral" activity where only
the data persists (if that). So let's run emulators and go home, job
done. (shrug) It's a matter of choices and consequences.
Regards, Herb Johnson
> On Fri, May 8, 2020 at 11:45 AM Herb Johnson wrote:
> This reply is long, because I'm arguing in opposition, and that means I
> have to make a case about, and explain about. But I'll save some
> people,
> some time. I"m going to fuss about these microcontrollers becoming
> obsolete. If you don't care about that, save time and stop reading here.
or try later herbjohnson AT retrotechnology DOT info
