[vcf-midatlantic] How To Geek article on floppy data recovery
Herb Johnson
hjohnson at retrotechnology.info
Fri May 8 18:45:06 EDT 2020
So, Gordon S. writes, something like this. He buys-in, that these
floppy-recover solutions, are made from currently available hardware,
but that hardware goes away over time. So, he says, why not implement on
widely available and well-sourced hardware? The challenge as he put it is:
"The only real irritant, then, becomes working out how to cheaply do
whatever it is these other projects are using FPGAs for. Those are the
parts that get updated whenever someone works out a better technique,
but... as a general rule, the interface to whatever vintage hardware is
more or less invariant, correct? That would mean the alterable functions
can be carried out in software rather than in (redefinable) hardware.
Flash updates are still flash updates, regardless of whether they
contain computer programs or FPGA configuration files."
"Can anyone poke holes in this? - Gordon S".
Well, I reject the limitation "cheaply". That constrains any modern
solutions to the hell of rapid obsolescence and proprietary solutions.
That's the current strategy. I'm being blunt but brief. At $10, $20
single-board single-chip solutions, how does any hobbyist outdesign
*that* with more persistent hardware?
The vintage hardware interface, is either a floppy drive for data
recovery; or a floppy drive controller, for diskette emulators (not
discussed but the complimentary device). Well, po-TAE-toe, po-TAUGHT-oe,
to a first order. That's not the hard part.
On FPGAs, and the hard part. Turns out the support page for the
Fluxengine, is pretty informative about this and other arguments for
alternative technologies. After five years, that's already been defended
(but I only read the gloss).
The defense is, it comes down to the design practice, of massive
oversampling of floppy data streams, to extract arbitrary-rates of
binary data relatively fast. Go to the site for details. So: one ether
borrows cheep ARM-class devices that do that, or cheep FPLA devices
which do that, or both. Because of that "cheap" constraint. Shrug.
In what used to be the real world, floppy disk controllers were
dedicated microprocessors with fast bit-serial/parallel hardware. Read
the early floppy controller FDC chip data sheets about that. They ran at
defined data rates - so write hardware was easier. Reading hardware
involved some skew, so one needed some tricks to sync-sample the read
data. We call that data, single/double density, FM/MFM. Or the Apple
mind-trick of the Apple II (later Mac) "Woz machine", a programmed-logic
device (!) to perform 3-of-5 encoding and decoding. Or, some custom
hardware and software, on other computers of vintage.
At one time, ALL floppy controllers were custom logic. (Search
retrotechnology.com ) Now, in some sense, the custom logic is in the
FPGA. This might make a case for preserving vintage computers (he he ...).
To replace all that, the cheat is to sample like hell and let
post-1990's computers sort out the results in software. Fair enough.
I appreciate Gordon's point, that functionality in modern devices is a
matter of programming, and reprogramming. That's fine, for those who
enjoy modern embedded programming. But when the hardware to be
programmed changes "too much"; the old software becomes obsolete.
Yesterday's FPLAs can't be programmed with today's FPLA tools. The codes
are changed too. The binaries are useless, even proprietary. That was my
point!
Subtle comment by Gordon: "We already know what stays around, or at
least remains well-documented and well-supported." Trick question. The
trick answer #1 is "that's the same thing". Answer #2 is "well, stuff
persists until it breaks; if you can't fix it you replace it". Sort of
the short version of the argument.
Now, the software to RUN the platform around the FPLA, could in
principle be standardized. For big-enough embedded systems, that's fine,
they are application-specific not implementation-specific (kinda). But
this is just a *floppy controller*. There *is no application*. Nobody is
running MS-DOS or Linux on these puppies. They are driven-by something,
the something steers it around, and that's all.
And by the way? The 1990's solution - the Catweasel, an ISA or PCI
bit-sampling controller on PC's? Last I checked, there were five-six
"installation solutions" for running that puppy. Surprisingly, each
developer came up with their own software to drive it. Go figure.
I don't know how much that happens, with 21st century $20
microcontroller solutions; the Arduino platform is pretty established;
the RaspPi, somewhat the same. Then each other device-family, has their
manufacturer's development engine software (to keep you from using
another product, he he). I made that point before.
So: walk through this with me. What floppy control hardware is pretty
much standardized, available, and stable; year after year and even into
decades? and what software to support what software to drive it, has
those qualities? Answer: XT/AT/386 class PC's and MS-DOS. And that's why
solutions like "Imagedsk" / MS-DOS / ISA floppy controllers / IMG files
just keep on workin'.
But they don't work for 68K Mac disk formats, Apple II disk formats,
etc. etc. That's why bit-sampling general solutions emerged in the
1990's, from Compaticard to Catweasel. And you know, maybe I'll think of
a 1985 solution to the problem for those reasons. But it's harder to
design PCI cards; many people don't have computers with PCI slots; USB
is the "bus" of choice; and there's those dammed $10, $20, $30
stick-puters. They are the black-holes of design-your-own-devices.
But the question of the day, was about a $10 solution. It's an amazing
bit of application, that FluxEngine; as is/was the GreaseWeasel. But
it's like other $10 embedded solutions, with all the faults I mentioned
and alternatives Gordon suggests. One can work around these, because in
the end, nobody is gonna die because a $10 embedded stick coughs and
sputters, or can't be found. There's no mission-critical task in play
that matters. They will come and go, as do supporters of some
application like read-a-floppy.
Sorry for the long lecture, I got a real question and it took time to
answer it. Hope this did that.
regards, Herb Johnson
or try later herbjohnson AT retrotechnology DOT info
