[vcf-midatlantic] Paper Tape readers from CNC machines
Duane Craps DBC1964 at cox.net
Mon May 18 14:29:13 EDT 2020
Jeff,
The Fanuc unit I have is an old pinch roller unit with a 50 pin connector.
It Uses +24 V0lts and +5 for logic
24 volts seems to be standard for machine tool servos.
Pins 23-24 are +24 Volts
22-21 are +5 Volts
Pins 1-8 are Bits 0-7
Pin 9 is the Data strobe
I think pin 10 is the run/stop but It had a manual switch on the unit
and used that
I have pin 12 written as ground but am not sure as I jumpered to a
capacitor on the board
The control signal is high-active so it should take off running with the
supplies energizes
The other UNIT is an sanyo demki 2702 in an OKUMA case that had a round
connector to plug into the machine tool.
I put in power supplies and aTeency Arduino clont to convert it to USB
It has a standard 44 pin edge connector on the logic board.
It was on EBAY and I noticed that no one was bidding so I got it for $4.50
I have some pictures but I dont think the list allows.
If you want the signals on the 2702 board let me know.
Good luck.
On 5/18/2020 12:44 PM, Jeff G via vcf-midatlantic wrote:
Duane Craps
sdɐɹɔ ǝuɐnp
DuaneCraps
sdɐɹɔ ǝuɐnp
