Swap Meet Reminder 11/7
svcatitc at aol.com svcatitc at aol.com
Mon Nov 2 10:18:25 EST 2020
If you click on Jeff Brace's link, Google thinks you want to be in the Tyrrhenian Sea !!
40°00'00.0"N 11°00'00.0"E
At first I thought Jeff is doing a little post Halloween spoof on us with his dry wit, however if you interrogate the link, you will see:
40.1848834,-74.0652735
which Google correctly identifies the coordinates as the Wall Twp municipal lot across from Brookdale Community College, Wall Campus on Monmouth Blvd.
So make sure your GPS's are correctly programmed for the above coordinates.
AND DON'T END UP IN THE DRINK!!
Bill Inderrieden
