[vcf-midatlantic] Televideo Model 925
Bill Degnan billdegnan at gmail.com
Sun Nov 22 16:27:01 EST 2020
Any terminal will work, or a computer running comm software.  If you're
going the comm software router, to start, avoid using a usb to serial
adapter and try to use a true serial port until you're sure the computer is
working with a serial terminal.  I have used all kinds of things with a
Compupro; Zenith,
 Just a question whether you need a null modem or not, I dont recall.  Does
it have the Interfacer card?
On Sun, Nov 22, 2020, 3:40 PM Bob Aviles via vcf-midatlantic <
> Hi,
> I am looking for a Televideo model 925 terminal with keyboard, 115/230V
> for my CompuPro S100 that I just received or any other type that works with
> the CompuPro S100 systems. Questions does anyone known if the Zenith EasyPC
> keyboard with work with the Compupro S100?
> Thanks
> Bobby
