[vcf-midatlantic] Televideo Model 925
Bill Degnan
billdegnan at gmail.com
Sun Nov 22 23:16:18 EST 2020
You can always bring it up, I have that term al and a same computer here
that work
B
On Sun, Nov 22, 2020, 10:28 PM Bob Aviles via vcf-midatlantic <
> Hi Bill,
> Just got the system need to check cards and other stuff, will get back
> to you on the null modem?I once went up to your store to buy a radio shack
> monitor years ago.
> ThanksBobby
> On Sunday, November 22, 2020, 04:27:53 PM EST, Bill Degnan via
> vcf-midatlantic <vcf-midatlantic at lists.vcfed.org> wrote:
> Any terminal will work, or a computer running comm software. If you're
> going the comm software router, to start, avoid using a usb to serial
> adapter and try to use a true serial port until you're sure the computer is
> working with a serial terminal. I have used all kinds of things with a
> Compupro; Zenith,
> Just a question whether you need a null modem or not, I dont recall. Does
> it have the Interfacer card?
> On Sun, Nov 22, 2020, 3:40 PM Bob Aviles via vcf-midatlantic <
> > Hi,
> > I am looking for a Televideo model 925 terminal with keyboard, 115/230V
> > for my CompuPro S100 that I just received or any other type that works
> with
> > the CompuPro S100 systems. Questions does anyone known if the Zenith
> EasyPC
> > keyboard with work with the Compupro S100?
> > Thanks
> > Bobby
