[vcf-midatlantic] Televideo Model 925
Bill Degnan
billdegnan at gmail.com
Mon Nov 23 07:32:21 EST 2020
Bobby,
Note back then that was the Wilmington Del. repair shop, now my business is
located in Kennett Square, PA. Kennettclassic.com for hours and location.
You'll need to make an appointment because I will need prep time to.set up
the Compupro and terminal. Do you have 8" drive(s), cables and boot media?
Bill
On Sun, Nov 22, 2020, 10:28 PM Bob Aviles via vcf-midatlantic <
> Hi Bill,
> Just got the system need to check cards and other stuff, will get back
> to you on the null modem?I once went up to your store to buy a radio shack
> monitor years ago.
> ThanksBobby
> On Sunday, November 22, 2020, 04:27:53 PM EST, Bill Degnan via
> vcf-midatlantic <vcf-midatlantic at lists.vcfed.org> wrote:
> Any terminal will work, or a computer running comm software. If you're
> going the comm software router, to start, avoid using a usb to serial
> adapter and try to use a true serial port until you're sure the computer is
> working with a serial terminal. I have used all kinds of things with a
> Compupro; Zenith,
> Just a question whether you need a null modem or not, I dont recall. Does
> it have the Interfacer card?
> On Sun, Nov 22, 2020, 3:40 PM Bob Aviles via vcf-midatlantic <
> > Hi,
> > I am looking for a Televideo model 925 terminal with keyboard, 115/230V
> > for my CompuPro S100 that I just received or any other type that works
> with
> > the CompuPro S100 systems. Questions does anyone known if the Zenith
> EasyPC
> > keyboard with work with the Compupro S100?
> > Thanks
> > Bobby
