[vcf-midatlantic] Televideo Model 925
Bill Degnan
billdegnan at gmail.com
Mon Nov 23 10:36:11 EST 2020
gotcha
On Mon, Nov 23, 2020 at 10:23 AM Bob Aviles via vcf-midatlantic <
> Hi Bill,
> Yes, I know you moved. I will probably make it next year, my wife not
> letting go anywhere.Thanks for the invite and Happy Thanksgiving.
> Bobby
> On Monday, November 23, 2020, 07:32:43 AM EST, Bill Degnan via
> vcf-midatlantic <vcf-midatlantic at lists.vcfed.org> wrote:
> Bobby,
> Note back then that was the Wilmington Del. repair shop, now my business is
> located in Kennett Square, PA. Kennettclassic.com for hours and location.
> You'll need to make an appointment because I will need prep time to.set up
> the Compupro and terminal. Do you have 8" drive(s), cables and boot media?
> Bill
> On Sun, Nov 22, 2020, 10:28 PM Bob Aviles via vcf-midatlantic <
> > Hi Bill,
> > Just got the system need to check cards and other stuff, will get back
> > to you on the null modem?I once went up to your store to buy a radio
> shack
> > monitor years ago.
> > ThanksBobby
> > On Sunday, November 22, 2020, 04:27:53 PM EST, Bill Degnan via
> > Any terminal will work, or a computer running comm software. If you're
> > going the comm software router, to start, avoid using a usb to serial
> > adapter and try to use a true serial port until you're sure the computer
> is
> > working with a serial terminal. I have used all kinds of things with a
> > Compupro; Zenith,
> > Just a question whether you need a null modem or not, I dont recall.
> Does
> > it have the Interfacer card?
> > On Sun, Nov 22, 2020, 3:40 PM Bob Aviles via vcf-midatlantic <
> > > Hi,
> > > I am looking for a Televideo model 925 terminal with keyboard, 115/230V
> > > for my CompuPro S100 that I just received or any other type that works
> > with
> > > the CompuPro S100 systems. Questions does anyone known if the Zenith
> > EasyPC
> > > keyboard with work with the Compupro S100?
> > > Thanks
> > > Bobby
