[vcf-midatlantic] Ordering Snark Barker MCA (Sound Boaster clone) PCBs -- Want One?
Alexander Jacocks
jjacocks at gmail.com
Mon Nov 30 14:10:08 EST 2020
Bill,
This is a build-it-yourself project. The Snark Barker is an exact clone, so
it's exclusively through hole.
Only the PCB is included. If others wanted, I could source the parts
necessary, but I'd need at least a few others interested.
- Alex
On Mon, Nov 30, 2020 at 7:38 AM Bill Degnan via vcf-midatlantic <
> Would the assembly be surface mounted or original?
> Bill
> On Sun, Nov 29, 2020, 8:43 PM Jameel Akari via vcf-midatlantic <
> > $34 I assume is just the board?
> > I’ll take a look at the details tomorrow but this might be fun.
> > Jameel Akari
> > > On Nov 29, 2020, at 8:17 PM, Alexander Jacocks via vcf-midatlantic <
> > > All,
> > > I'm in the process of ordering PCBs for the Snark Barker MCA
> > > (microchannel), which was just announced, here:
> > > https://twitter.com/TubeTimeUS/status/1333123576346468352
> > > The design files and BOM can be found here:
> > > https://github.com/schlae/snark-barker-mca
> > > I'll be ordering from PCBway, who does gold fingers, so that the boards
> > > will be able to be able to be repeatedly inserted, without wearing out
> > the
> > > contacts.
> > > Is anyone else interested? The cost (at quantity 5) would be about
> > > $34+shipping, per PCB. The cost should go down with a bigger order,
> > should
> > > more than 4 others want boards. I could probably be convinced to make
> the
> > > parts order, as well, if folks want.
> > > Thanks!
> > > - Alex
