[vcf-midatlantic] Ordering Snark Barker MCA (Sound Boaster clone) PCBs -- Want One?
Alexander Jacocks jjacocks at gmail.com
Mon Nov 30 18:04:26 EST 2020
Thanks, Z. Did you already build one?
- Alex
On Mon, Nov 30, 2020 at 17:32 Alexander Pierson via vcf-midatlantic <
>  The Snark Barker MCA does have a limited number of surface mount
> components, namely the CPLD, associated voltage regulator, and some
> capacitors. Everything else is thru-hole.
> Meanwhile, the ISA Snark Barker is fully thru-hole.
> -Alexander 'Z' Pierson    On Monday, November 30, 2020, 04:55:15 PM EST,
> Alexander Jacocks via vcf-midatlantic <vcf-midatlantic at lists.vcfed.org>
> wrote:
>  Bill,
> This is a build-it-yourself project. The Snark Barker is an exact clone, so
> it's exclusively through hole.
> Only the PCB is included. If others wanted, I could source the parts
> necessary, but I'd need at least a few others interested.
> - Alex
> On Mon, Nov 30, 2020 at 7:38 AM Bill Degnan via vcf-midatlantic <
> > Would the assembly be surface mounted or original?
> > Bill
> > On Sun, Nov 29, 2020, 8:43 PM Jameel Akari via vcf-midatlantic <
> > > $34 I assume is just the board?
> > > I’ll take a look at the details tomorrow but this might be fun.
> > > Jameel Akari
> > > > On Nov 29, 2020, at 8:17 PM, Alexander Jacocks via vcf-midatlantic <
> > > > All,
> > > > I'm in the process of ordering PCBs for the Snark Barker MCA
> > > > (microchannel), which was just announced, here:
> > > > https://twitter.com/TubeTimeUS/status/1333123576346468352
> > > > The design files and BOM can be found here:
> > > > https://github.com/schlae/snark-barker-mca
> > > > I'll be ordering from PCBway, who does gold fingers, so that the
> boards
> > > > will be able to be able to be repeatedly inserted, without wearing
> out
> > > the
> > > > contacts.
> > > > Is anyone else interested? The cost (at quantity 5) would be about
> > > > $34+shipping, per PCB. The cost should go down with a bigger order,
> > > should
> > > > more than 4 others want boards. I could probably be convinced to make
> > the
> > > > parts order, as well, if folks want.
> > > > Thanks!
> > > > - Alex
