[vcf-midatlantic] Cleaning Franklin cases
Herb Johnson
hjohnson at retrotechnology.info
Fri Oct 2 15:17:09 EDT 2020
Regarding cleaning chemicals, "Simple Green" is pretty useful stuff. It
contains ether, which is a good but not overly aggressive solvent that
dissipates rapidly. It is more aggressive than alcohol but of course
it's also a kind of detergent which must be washed away. It's commonly
available in spray bottles or nonspray.
I'd wear rubber gloves and work outside for any cleaning with chemicals,
if I were you. This stuff is not good for you.
Regards, Herb Johnson
or try later herbjohnson AT retrotechnology DOT info
