[vcf-midatlantic] TI-99/4A Peripheral Expansion Box - Voltages
Mike Loewen
mloewen at cpumagic.scol.pa.us
Sat Oct 3 15:40:50 EDT 2020
Mark:
I ran that PEB for an hour last week, with no problems.
Mike Loewen mloewen at cpumagic.scol.pa.us
Old Technology http://q7.neurotica.com/Oldtech/
On Sat, 3 Oct 2020, Mark Whittington via vcf-midatlantic wrote:
> Thanks Glenn and Mike for the responses.
> I did download the schematic, and I found and read the technical
> information here: http://www.unige.ch/medecine/nouspikel/ti99/pebox.htm
> before powering the unit, but I was unable to find a manual. If you know
> where I can find one I'd appreciate a link.
> I'll check the capacitors and put a load on the various supply rails and
> see if that brings the voltages down.
> Thanks again.
> Mark
> On Sat, Oct 3, 2020 at 10:10 AM Sentrytv <sentrytv at yahoo.com> wrote:
>> Also I?m assuming you downloaded the manuals and the schematic for the
>> power supply first before plugging in?
>> Sent from:
>> My extremely complicated, hand held electronic device.
>>> On Oct 3, 2020, at 7:24 AM, Mark Whittington via vcf-midatlantic <
>> vcf-midatlantic at lists.vcfed.org> wrote:
>>> Just realized I missed a half a sentence (in my defence it's a been a
>> late
>>> night).
>>> The corrected sentence:
>>> 2) Is just a case of not having a load on the outputs causing them to run
>>> high? I know that the linear regulators that are likely to be used on
>> any
>>> cards can technically handle these inputs, but I wouldn't want to assume
>>> that they have heat sinks large enough to dissipate the extra power for
>>> very long, so I haven't been brave enough to test the system with cards
>> in
>>> it to present a load.
>>> Thanks
>>>> On Sat, Oct 3, 2020 at 7:19 AM Mark Whittington <markwhi at gmail.com>
>> wrote:
>>>> Does anyone here have much experience with these? I picked one up
>>>> recently and I've been going over it before plugging things in. I
>> tested
>>>> the unloaded voltages with the transformer set to 115VAC and got the
>>>> following on the unregulated DC output rails:
>>>> +8V rail: 14.4V
>>>> +16V rail: 25.2V
>>>> -16V rail: -25.3V
>>>> It looks like a previous owner had it apart -- there are hand-written
>>>> labels on the various input taps for the transformer, so I thought that
>>>> perhaps it was mis-wired on reassembly. But testing the other taps the
>>>> best result I can get is with the 220VAC tap at approx. +7.5V and +/-
>> 12V
>>>> on the unregulated outputs.
>>>> My analog circuits knowledge is pretty thin, so I'm hoping someone here
>>>> might be able to help out. My questions are:
>>>> 1) I've measured the output taps from the transformer for each of the
>>>> various input taps and they match what I'd expect to see as inputs given
>>>> the various rectified outputs (RMS AC -> Peak AC, minus a diode drop)
>> so I
>>>> don't *think* the problem is on the power supply board. Am I missing
>>>> something?
>>>> The schematic I've been referencing:
>>>> http://www.mainbyte.com/ti99/schematic/peb_power.jpg (I have the -2
>>>> version)
>> run
>> any
>>>> very long.
>>>> 3) Is this actually normal?
>>>> Thanks in advance for any help.
