[vcf-midatlantic] Project of the day - Windows 3.11 386Enh on a floppy
Richard Cini
rich.cini at gmail.com
Sat Sep 5 19:28:02 EDT 2020
Yeah, I thought of that too. I did this within Parallels on my Mac (so, going back and forth between Windows XP and MS-DOS 6.22 running as virtual machines) and Parallels doesn't support DMF (or anything other than 1.44MB). Neither does VirtualBox interestingly. It might be possible to do it on a real PC, but not sure.
Yes, that extra 200k would make a huge difference in what could be included. Another way, that I haven't dried, is using Doublespace to create a virtual drive on the floppy.
Rich
Rich Cini
http://www.classiccmp.org/cini
http://www.classiccmp.org/altair32
On 9/5/20, 7:23 PM, "vcf-midatlantic on behalf of John Heritage via vcf-midatlantic" <vcf-midatlantic-bounces at lists.vcfed.org on behalf of vcf-midatlantic at lists.vcfed.org> wrote:
How about using one of the extended disk formats - 1.68MB or whatever
format IBM Used for their OS/2 floppies? or is that not bootable? (This
format was at least readable by standard 1.44 MB drives using standard
1.44MB disks.. )
Interesting challenge !
On Sat, Sep 5, 2020 at 7:20 PM Richard Cini via vcf-midatlantic <
> Not really sure what applicability this really has, but today’s challenge
> was to get Windows 3.11 Enhanced Mode running from a single 1.44MB floppy
> disk. There are easy ways to get Standard mode running, including using
> files from “precopy.cab” on Windows 95 or 98, but this was way more
> challenging. I started from a full install and pared it down using a guide
> I found (which was a two-disk solution).
> The boot files and required extras (HIMEM, PKUNZIP and a very small
> ramdrive driver) took about 300K, leaving only about 1.2MB (1.156MB to be
> exact) for a complete install. A normal no-frills install is about 3-ish
> megabytes.
> There are significant compromises – no virtual memory, no networking, no
> multimedia, only system fonts, and only a few apps, but once running you
> could run them from another floppy. I discovered that 386Enh won’t put a
> temporary swapfile on a RAM drive, so it runs without it.
> I guess you could call this the 1992 version of PortableApps :-)
> Rich
> Rich Cini
