[vcf-midatlantic] Project of the day - Windows 3.11 386Enh on a floppy
Richard Cini rich.cini at gmail.com
Sun Sep 6 13:42:04 EDT 2020
I forgot to answer your original question about systems. I built the disk using DOS 6.22 and Windows XP, both running on Parallels (on a Mac). Parallels emulates a standard PC but uses virtualization to work.
Anyway, I would expect that if runs on that, it will run on any PC after 1992.
Here’s the file list:
 Volume in drive Z is MS-RAMDRIVE
Directory of Z:\WINDOWS
.            <DIR>         09-06-20   5:38p
..           <DIR>         09-06-20   5:38p
ACCESSOR GRP         2,206 09-05-20   7:52p
CONTROL  EXE        15,872 12-31-93   6:11a
CONTROL  INI         3,824 09-05-20   6:38p
DOSPRMPT PIF           545 09-05-20   2:14p
DRWATSON EXE        26,864 09-06-20  12:14p
MAIN     GRP         5,115 09-05-20   7:52p
MOUSE    INI            24 09-05-20   2:12p
NOTEPAD  EXE        32,736 09-06-20  12:14p
PRINTMAN EXE        43,248 09-06-20  12:14p
PROGMAN  EXE       115,312 12-31-93   6:11a
PROGMAN  INI           168 09-06-20  12:37p
REG      DAT         2,556 09-05-20   2:14p
STARTUP  GRP            44 09-05-20   7:52p
SYSEDIT  EXE        19,472 05-26-95   6:57a
SYSTEM   INI         1,501 09-05-20   7:52p
SYSTEM       <DIR>         09-06-20   5:38p
TASKMAN  EXE         3,744 09-06-20  12:14p
WIN      COM        44,170 09-05-20   2:12p
WIN      INI         3,424 09-05-20   2:14p
WINFILE  EXE       146,864 12-31-93   6:11a
WINFILE  INI            96 09-05-20   7:02p
_DEFAULT PIF           545 09-05-20   2:14p
       24 file(s)        468,330 bytes
Directory of Z:\WINDOWS\SYSTEM
COMM     DRV         9,280 12-31-93   6:11a
COMMCTRL DLL        48,112 05-26-95   6:57a
COMMDLG  DLL        97,936 12-31-93   6:11a
CPWIN386 CPL       104,816 12-31-93   6:11a
DOSX     EXE        32,682 12-31-93   6:11a
DRIVERS  CPL        41,440 12-31-93   6:11a
GDI      EXE       220,800 12-31-93   6:11a
KEYBOARD DRV         7,568 12-31-93   6:11a
KRNL386  EXE        76,400 12-31-93   6:11a
LANMAN10 386         8,786 12-31-93   5:11a
LZEXPAND DLL        23,712 12-31-93   6:11a
MAIN     CPL       148,560 12-31-93   6:11a
MMSOUND  DRV         3,440 12-31-93   6:11a
MMSYSTEM DLL        61,648 12-31-93   6:11a
MOUSE    DRV        10,672 12-31-93   6:11a
SETUP    INF        60,594 12-31-93   6:11a
SHELL    DLL        41,600 12-31-93   6:11a
SND      CPL         8,192 12-31-93   6:11a
SYSTEM   DRV         2,304 12-31-93   6:11a
TTY      DRV        30,496 12-31-93   6:11a
USER     EXE       264,016 09-05-20   2:14p
VER      DLL         9,008 12-31-93   6:11a
VGA      3GR        16,384 12-31-93   6:11a
VGA      DRV        73,200 12-31-93   6:11a
VGAFIX   FON         5,360 12-31-93   6:11a
VGAOEM   FON         5,168 12-31-93   6:11a
VGASYS   FON         7,280 12-31-93   6:11a
VTDA     386         6,816 12-31-93   5:11a
VTDAPI   386         5,245 12-31-93   6:11a
WIN386   EXE       544,789 12-31-93   6:11a
WINOA386 MOD        49,248 12-31-93   6:11a
WSWAP    EXE        16,302 12-31-93   6:11a
       34 file(s)      2,041,854 bytes
Total files listed:
       58 file(s)      2,510,184 bytes
                       5,738,496 bytes free
Rich
Rich Cini
http://www.classiccmp.org/cini
http://www.classiccmp.org/altair32
On 9/6/20, 11:47 AM, "John Heritage" <john.heritage at gmail.com> wrote:
Very nice!  That's stackering the Win 3.11 boot disk itself?  I am curious how much that compresses..
Also, would that work on a 'modern' PC - such as a Socket 7 system? (of ~ Pentium MMX era/vintage)?   I have a K6-3+ BIOS modded Socket 7 system I use for fun.  (OC'd to 75 MHz bus = 450 MHz).
On Sat, Sep 5, 2020 at 8:33 PM Richard Cini <rich.cini at gmail.com> wrote:
Ha, just pulled out a copy of Stacker 4.0 and compressed a floppy disk. 2.8MB free. That's a lot of room :-)
Rich
Rich Cini
On 9/5/20, 7:28 PM, "Richard Cini" <rich.cini at gmail.com> wrote:
    Yeah, I thought of that too. I did this within Parallels on my Mac (so, going back and forth between Windows XP and MS-DOS 6.22 running as virtual machines) and Parallels doesn't support DMF (or anything other than 1.44MB). Neither does VirtualBox interestingly. It might be possible to do it on a real PC, but not sure.
    Yes, that extra 200k would make a huge difference in what could be included. Another way, that I haven't dried, is using Doublespace to create a virtual drive on the floppy.
    Rich
    Rich Cini
    On 9/5/20, 7:23 PM, "vcf-midatlantic on behalf of John Heritage via vcf-midatlantic" <vcf-midatlantic-bounces at lists.vcfed.org on behalf of vcf-midatlantic at lists.vcfed.org> wrote:
        How about using one of the extended disk formats - 1.68MB or whatever
        format IBM Used for their OS/2 floppies?   or is that not bootable?   (This
        format was at least readable by standard 1.44 MB drives using standard
        1.44MB disks.. )
        Interesting challenge !
        On Sat, Sep 5, 2020 at 7:20 PM Richard Cini via vcf-midatlantic <
        > Not really sure what applicability this really has, but today’s challenge
        > was to get Windows 3.11 Enhanced Mode running from a single 1.44MB floppy
        > disk. There are easy ways to get Standard mode running, including using
        > files from “precopy.cab” on Windows 95 or 98, but this was way more
        > challenging. I started from a full install and pared it down using a guide
        > I found (which was a two-disk solution).
        > The boot files and required extras (HIMEM, PKUNZIP and a very small
        > ramdrive driver) took about 300K, leaving only about 1.2MB (1.156MB to be
        > exact) for a complete install. A normal no-frills install is about 3-ish
        > megabytes.
        > There are significant compromises – no virtual memory, no networking, no
        > multimedia, only system fonts, and only a few apps, but once running you
        > could run them from another floppy. I discovered that 386Enh won’t put a
        > temporary swapfile on a RAM drive, so it runs without it.
        > I guess you could call this the 1992 version of PortableApps :-)
        > Rich
        > Rich Cini
