[vcf-midatlantic] LSI-11 simulator
Herb Johnson
hjohnson at retrotechnology.info
Thu Sep 10 12:23:59 EDT 2020
> No RT-11 disk image I’ve used will boot,
> I was hoping someone could point me to a listing of what the on-disk boot block code on an RT-11 floppy might look like.
Rich, I don't understand your problem. If you have access to RT-11 disk
images on the Web, my guess is some of them are "bootable". By
"bootable" that means by your account, they have PDP11 boot code on
their first sector. If they have boot code on their first sector - then
extract the first sector and *hand disassemble the binary*. Then you
know what that code quote "looks like".
256 words (512 bytes) is just a handful of disassembly work - hardly
worth bothering to run an emulator to run some debugger to produce some
PDP-11 code. and you seem so deep into this custom emulator and the
LSI-11 architecture, that you seem to know what you'd need to make sense
of the boot code. I'm familiar with PDP-11's a little, it's not
horrendous binary code.
YOu also say, this emulator apparently needs a custom RT-11, presumably
with custom boot code. But the creator doesn't recall the details. Well,
24 years is a long time to remember such things. That being the case,
you will have to figure out the boot process anyway. You already have to
dig into the emulator. And you seem to know the hardware. Thus doing the
hand disassembly will be, er, "informative".
What am I missing here? Do you need some known bootable RT-11 diskettes,
so you can put one in some drive and read off the boot sector? Or
someone to send you that binary or disk image?
Likewise:
> It’s like looking for a disassembly of the MS-DOS boot sector.
(snort) MS-DOS DEBUG will do that, with a IBM PC tech manual in hand.
I don't mean to belabor the point, but maybe this is as I suspect: a
desire to avoid hand-disassembly. If that's a personal issue, my
apologies, but I think it's a very useful skill. And if it's not a
desirable task, well, there's usually debuggers which do that, or one
can cobble up a disassembler in one's favorite language (or borrow one
and rework it). I've done all those things, and still do, but that's
just me.
Puzzled, Herb
or try later herbjohnson AT retrotechnology DOT info
